Top Hearing AIDS maintenance tips
Top Hearing AIDS maintenance tips - wave speech and hearing equipment, Delhi
The hearing aid investment is a life-changing decision. But for them effectively and long working, it is important that they are maintained regularly. A famous hearing clinic in-Delhi in Tarang Speech and Hearing AIDS, we not only provide world class hearing AIDS, but also provide professional advice to maintain them in the right position. Here are the Top hearing AIDS maintenance tips that you have to follow:
  1. Keep the hearing instruments dry:
The biggest cause of damage is moisture. Always remove your hearing instruments while bathing or swimming. To keep your hearing devices dry at night, dehumidify your hearing instruments using a hearing aid dehumidifier.
  1. Clean your hearing device daily:
How to clean the hearing device is a question that arises often. Gently clean them daily with a dry cloth. Remove wax or dust from the receiver and microphone using a soft brush.
  1. Change wax guard regularly:
Earwax can block the hearing device. Recommended by the Wax Guard to repeatedly recommended by his audiologist or to prevent sound deformation.
  1. Change the battery on time:
Low battery performance. Keep the spare batteries available easily and change them as soon as you feel that sound quality has decreased.
  1. Treat with care:
Do not leave your equipment. Store them safely when not in use, away from heat or moisture.
  1. Arrange for routine servicing:
    Regular check-ups and professional cleaning are necessary. For the best care, visit your hearing aid specialist regularly in Delhi.
Is help or maintenance services required?
Call us and Book your Free Appointment Today : ‪+91 8506814814
Visit Our Clinic Today : 127, Hargobind Enclave, Karkardooma, Anand Vihar, New Delhi, Delhi, 110092
Ground Floor, A-3, Block A, Shivalik Colony, Malviya Nagar, New Delhi, Delhi 110017
Post Your Comment
Request a Call Back
